Is it a Gas Valve or a Water Valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, May 23, 2011.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Hi,
    I was told by a natural gas company service person that a ball valve (shut-off) in a 1/2 inch gas line was for water and not gas.
    How can he tell the difference? This is an older valve with no labels. Many ball valve shut-offs are for water and natural gas.
    Thanks,
    Bill
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    What color is the handle?
    I bought a bunch of valves today,
    THe gas valves had yellow handles on them.
    On the side in the casting it had "1/2 psi"
    Not sure what the other colors are off hand, Red & Green....
    Michael
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It will have WOG stamped on the valve. (water-oil-gas)
  5. wallskev
    wallskev New Member
    May 14, 2009
    Manufacturing Consultant
    North Carolina,USA
    Handle Color not the Clue !
    I would not go by the color of the Handle. I have many yellow handled Water ball valves and even a Blue Handle Gas valve.
    Most have a rating stamped on them. You will see WOG on the side. This stands for Water, Oil or Gas. Most gas valves are brass and much heavier than standard valves. The difference is in the internal sealing of the ball. Gas valves are better.
    Most of the ones I could check have WOG on them. I have 1 with just a G on it . Also don't go by the Handle type either as I have a gas Ball valve with a long handle (Red).
    Possibly there is some other evidence that will help. The 1/2 psi indication , if there is no G would make me think it is for water but I am not a valve manufacturer.
  6. hj
    The color of the handle usually identifies the manufacturer, NOT the valve's usage. Valves with WOG on them are for liquid gas, unless they also have the AGA tag. Technically, they are NOT natural gas valves but do function for that purpose. AGA certified valves are usually less expensive, however.
  7. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The ball-valve had a red handle and no markings. I do not know how the gas company determined it was a water valve and not a gas valve.
  8. hj
    Usually, just by looking at it. Gas valves have a distinctive appearance. The red handle just happens to be the color the manufacturer liked.
  9. jimbo
    jimbo Plumber
    I don't know if we have a definitive answer here yet. I always thought that to be used for gas, the valve had to be AGA listed.
Similar Threads: Valve Water
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Turned one shut off valve now there is NO water in bathroom sink. HELP Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Water Pressure Reducing Valve - Signs of Failure ? Nov 28, 2016
