Is 1/2 inserted into ABS fitting OK?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buttonsrtoys, Jan 21, 2013.
  1. Buttonsrtoys
    Buttonsrtoys New Member
    Nov 1, 2012
    Nova Scotia, Canada
    I'm just finished installing my 3" drain for a new powder room. I got the pipes inserted the full 1.5" in each fitting except one pipe that was in a really cramped spot, which I only got inserted half way (3/4") into the fittings on each end. Its supported with straps and well glued. Because it's in such a cramped spot, I'm hoping not to have to take it out. Is it OK?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The short answer is No. The long answer is Noooooooooooooooooooooooooooooo
  4. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Can you elaborate? is the concern that it will fail down the road even of it's not leaking now?
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    Read your code book.
  6. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    I'm a home owner. I don't have a code book. Regardless, I'm just liking to know whether it will hold.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If it's installed 50% of the way, there is a 50% chance of it failing.
    Your goal in any DIY project should be to do it at least as good as a professional tradesman would.
    Plastic fittings and cement are cheap. You should cut it out and fix it.
Similar Threads: inserted fitting
Plumbing Forum, Professional & DIY Advice How far down should bush be inserted into shower drain Oct 31, 2011
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Viega press fittings for PEX Sep 12, 2016
