Iron staining, Sulfur smell, water options
Discussion in 'Water Softener Forum, Questions and Answers' started by astraelraen, Aug 6, 2012.
  1. Gary Slusser
    Retired
    Man... yes it is PEX and it says PEX on it and you're still questioning. Deep breath and change your thinking to how to do the plumbing and you'll feel better shortly.
    3/4" PEX (copper, CPVC) has a 7/8" OD, 1" will be about 1.25".
    You are worrying about nothing, you'll never notice the "bottleneck" you imagine. When water comes to a restriction in its flow, it speeds up through the restriction and then slows back down. The restriction in the BP valve is very smooth and causes no noticeable loss of flow.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The OD on PE may vary because with PE the ID needs to be consistant because the fittings for PE go inside the pipe. PE is the only pipe I know of that uses insert fittings.
  3. Gary Slusser
    Retired
    The OD varies based on the pressure rating and the consistent ID allows the use of insert fittings because of the semi-flexible nature of PE pipe.
    Plus there is a lot of PE tubing that uses compression fittings but not insert fittings.
    And PEX, because of it also being semi-flexible like PE pipe and PE tubing, it can use both insert and compression fittings.
  4. Tom Sawyer
    Nov 29, 2010
    Maine
    PE or HDPE is Polyethylene or high density polyethylene pipe of which the outside diameter may vary and does not matter because the fittings go inside the pipe. I believe that PE and HDPE are the only piping systems that use insert fittings except for pex. Sharkbite fittings and similar fittings like John Guest etc will not fit on PE or HDPE pipe. The only other pipe that is commonly called "poly" would be Polybutlyene which does have a standard outside diameter same as pex or copper or cpvc.
  5. ditttohead
    Jan 9, 2012
    Ontario California
    Gary said it perfectly. A short bottleneck will lower the systems potential maximum flow, but the bypass has a maximum flow in excess of 30 GPM, the systems, valves etc typically max out at the 10-15 GPM range. Also, the boot will flex out of the way considerably more than shown in your picture. Your concerns are excellent, but nothing to worry about. The velocity (speed) of the water will increase in this section of the bypass, but you will not notice any reduction flow. Plumbing is designed with velocities in mind, and the common maximum is 8 feet per second. The flow may increase to 20 FPS inside that bypass, but only at higher flow rates, in excess of 10 GPM.
    Most people never even notice the stainless bypass flow port size. This bypass design has been in use for may decades, with millions installed, you will be fine. Now if your house is plumbed in 1-1/4" or larger, I would not recommend this bypass, but Fleck does make a 1-1/4" sweat adapter for it.
  6. Gary Slusser
    Retired
    Yeah all pipe has a variable OD and consistent ID and all tubing has a consistent OD and the ID varies.
    PB/polybutlyene is semi flexible tubing, as is PE and PEX so the OD is consistent and the ID varies. PB used both insert and compression fittings as all other semi flexible plastic tubing does. Metal and rigid plastic tubing (copper, CPVC) or pipe (steel, PVC) can not use insert fittings.
    Or, you are wrong if you mistakenly think PE pipe was invented just so it could use insert fittings. PE tubing uses insert and/or compression fittings, although PE tubing is not used for pressurized water distribution lines.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    I believe that originally PE was designed to be butt fusion welded but there are other methods that will join it also including a variety of exterior clamp type couplings and other fittings that use a rubber gasket in compression to make the seal. You can not legally use PE or HDPE withing the structure for pressurized water distribution. PE variants are also being used for gas distrubution and gas mains. Many localaties have switched from ductile iron for water mains to HDPE (butt fusion welded) with the distribution laterals also being HDPE and run to the inside of the house, directly to the water meter. We have been using PE for water pumps for many years.
  8. Gary Slusser
    Retired
    Yeah I didn't mention that stuff because I was talking residential water lines.
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    Well good then. I think all the bases have been covered
  10. astraelraen
    astraelraen New Member
    Aug 6, 2012
    ID
    Well I finally got all the fittings and installed it today. It took probably 2 1/2 hours once all was said and done. I've still got a microscopic leak coming from one of the fittings that goes into the bypass valve, but it's literally like one drip every 5 minutes.... so I'm not worried about it right now.
    Smell is gone from cold water line, haven't really ran much hot water but I understand it will probably take a few days to cycle the water in the water heater.
    I haven't backwashed the carbon and didn't really let it soak all that long, which I read it was ideal to let it soak for awhile before putting it into operation. I ran a faucet until it ran clear. The discharge was blackish for probably 5-10 minutes.
    The only "weird" thing I've noticed is that the water actually tastes "dry." It's kinda strange. I'm guessing it will take a few days or a week for everything to get up and normalized.
    You guys were a ton of help. If you lived nearby I'd take you for coffee or a beer :D
  11. Gary Slusser
    Retired
    That water drip will probably stop on its own if it is on the inlet side of the BP.
    Carbon, and all other types of filters and softeners really need to be in the backwash cycle position as the water is turned on during installation and before running water through the bed. Running water to a faucet compacts the bed trapping 'fines' etc.. You do one piece of equipment after the other by putting other backwashed or regenerated equipment past the one you're filling in by pass.
    Thanks. I'd go for a beer or two but ya gotta watch Tom, the word is that he's been known to get emotional after a couple adult beverages.
  12. Tom Sawyer
    Nov 29, 2010
    Maine
    Tom hasn't had a drink in thirty years or so but......I have to admit that at times, sparring with you makes me think about that decision. So how was your summer? They say it was pretty darn hot out your way. Are you staying for the winter or heading for Florida?
  13. Gary Slusser
    Retired
    Yeah I'm not buying that 30 years, but we have been in FL since spring checking out the water treatment businesses around Ocala ya know. Once I'm done here in a few months, we will be headed west to become Texans (again). Maybe open me another business and then head west to the high country for the summer. Or....
Similar Threads: Iron staining
Water Softener Forum, Questions and Answers iron staining water Dec 14, 2013
Water Softener Forum, Questions and Answers Best Water Filter for Low amounts of Iron, Magnesium, and Manganese Feb 20, 2017
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers Iron threshold for dedicated filter Feb 5, 2017
Water Softener Forum, Questions and Answers Lots of iron. Best whole house and best pitcher filter Feb 3, 2017
