Iron Removal for single tub.
Discussion in 'Water Softener Forum, Questions and Answers' started by Gast, Jun 17, 2010.
  1. Gast
    Gast New Member
    Jun 17, 2010
    GA
    My parents have a tub with water jets that hasn't been hooked up to the water lines for almost 10 years due to fear that our well water will destroy the tub. I'm pretty sure we've got hard water and a sizable iron count. I really don't have the budget to put in a whole house system, so I'd like to know if I have any options for a smaller scale iron filter. (Ha! Sorry for pun.) My only goal is to get the water quality to a point that it won't harm the tub. I'll try and get the water tested soon.
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    first test the water and the results will give you your options.
  4. Gast
    Gast New Member
    Jun 17, 2010
    GA
    Aww, I was hoping for some ideas before then. I was told it takes an average of a week to get results for water tests done by the county. IIRC our iron was in the single digits (3-5), and I remember being well into the "hard water" category.
  5. jadnashua
    Depending on how much, and what type of iron compound is in the water would determine how you could remove it, and what would work. A softener can remove some iron in the process of softening the water, but if the water is very heavily loaded, you may need other process(es) to clear it. You may want to do this for the whole house, as getting access to the supply and having room for maintenance and the initial install could be tough.
  6. Gast
    Gast New Member
    Jun 17, 2010
    GA
    Access to the supply and room to install and maintain any system installed is not really a problem, overall cost is. When we built the house there was a miscommunication about the crawl space height, so it's now more of a crouch space, and the access door is under the bathroom in question. And there's enough space in the bathroom itself to potentially build a cabinet to house a system right next to the tub.
    As for cost, I'd have to keep it under $500, preferably under $200. I'm fairly handy and plan on installing the system myself.
  7. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    Iron stains but does not generally destroy surfaces like a tub. If there is high iron content then other surfaces (sinks, toilets, etc) are staining and you can expect the same with the tub. So why do you have special concerns about the tub?
  8. Gast
    Gast New Member
    Jun 17, 2010
    GA
    It's a whirlpool or jacuzzi tub. It has water jets and pumps and stuff that my parents won't think will hold up well to the water. The shower heads don't fare so well, so I can understand their concern.
  9. Bob999
    Jul 4, 2009
    Pennsylvania
    Good reasons to treat all the water--not just for the tub. But as Wally said--you need a water test before anyone can give you informed advice.
    Added: An additional consideration is tubs have both hot and cold water supply and most filters are not rated to use with hot water. That means you need to treat the water before it enters the hot water heater.
Similar Threads: Iron Removal
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal 33 minutes ago
Water Softener Forum, Questions and Answers Sulfate and Iron removal Nov 2, 2016
Water Softener Forum, Questions and Answers Iron removal Jul 25, 2016
Water Softener Forum, Questions and Answers Iron Breaker III vs KDF 85 for Iron removal Dec 31, 2015
Water Softener Forum, Questions and Answers Irrigation Well Iron removal system recommendations ***UPDATE*** Sep 10, 2015
