Iron pre-filter for RO
Discussion in 'Water Softener Forum, Questions and Answers' started by OldBat, Jun 20, 2013.
  1. OldBat
    OldBat New Member
    Jun 20, 2013
    North Georgia
    Hi, new here. On a drilled well and have suffered with clear water iron >5PPM plus iron bacteria for years. Simple filters are not effective and every time I have researched something that might work it was cost prohibitive.
    Was recently given a 5 stage with RO for just drinking water. Have it mostly installed but not hooked up yet because iron is one of the few things it can not handle. While the manufacture recommends an iron pre-filter they will not recommend a *specific* one since they do not sell them... Argh!
    Want to avoid the expense of any thing whole house so what are my options? Will a washable ceramic be enough? Do they make a tiny softener system that can handle iron that high? Currently buying an average of 3 1/2 gallons per day for drinking and cooking, so 1 gallon per hour should still be plenty even with the RO wasting 2 gallons for every 1 produced.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Chlorene injection
  4. ditttohead
    Jan 9, 2012
    Ontario California
    When was the last time you had the water tested? Can you post those results? Otherwise we are just wild guessing. Tom hit it right with Chlorine injection to start. But what to do after that?
    FYI, RO's do not typically run at a 2:1 ration, depending on the system design, 4:1 - 8:1 is more common. If you are running at a 2:1 ratio, the water should be carefully pre-treated or you will be replacing membranes regularly.
  5. OldBat
    OldBat New Member
    Jun 20, 2013
    North Georgia
    Thanks both! Searching for "chlorine injection" and not liking what I have found so far. Complete systems that are way over my budget and components that are not specked in a friendly to DIYSers way. Will keep searching...
    Last professional test was long ago. Just ran a cheep kit a few days ago to re-confirm what we have know for almost 20 years. Iron is off the scale and a few other minor issues that are trivial to fix.
    The 2:1 ratio is from the RO filters literature. Have not started using it yet so can not confirm. None of the reviews, even the negative ones, mentioned this so I have to take their word.
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Check this online vendor's "Complete Guide to Home Chlorination Systems" at http://www.cleanwaterstore.com/chlorinator.html. It's a pretty comprehensive, step-by-step guide to choosing a chlorinator system. It's got some prolems:
    1) They sell Stenner injection pumps, which some pro's like, others don't;
    2) They suggest injecting the chlorine before the pressure tank, which some pro's like, others don't;
    3) They say you can't use bleach for the chlorine solution, but that's not true for Clorox brand;
    4) They show a carbon filter (required as part of the system) in their illustrations, but don't give much detail. There are many discussions of carbon filters on this forum.
    And, of course, the cost problem remains, but you get what you pay for.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Yea, unfortunately there is no cheap way out of treating IRB and clear water iron and both will mess the RO filter up in short order.
  8. OldBat
    OldBat New Member
    Jun 20, 2013
    North Georgia
    Sorry for the delay, just received my TDS meter today. Good news is that it is only 55 ppm and agrees with the test strip result below. Not a whole lot worse than our bottled water at 16 ppm.
    Mikey, thanks for the lead! ~$500 is a bit more palatable than the $1,200 I had been finding for 'systems'. Will continue to research various chlorine injectors though it looks like a whole house is my only option.
    Summary of test strip results:
    Iron > 5ppm
    Copper 0
    Nitrate < 5ppm
    Nitrite 0
    Chlorine 0
    pH 5
    Alkalinity 80ppm
    Hardness 3 grains (or 50ppm)
    Iron bacteria confirmed by slime in toilet tank.
  9. ditttohead
    Jan 9, 2012
    Ontario California
    http://www.qcsupply.com/advancedsearch/result/?q=chemilizer
    Here is a link for a company that sells the Chemilizer. You should remove the chlorine after you inject it with a carbon tank and a contact tank is often used to give the chlorine time to do its job.
    Let us know what your plans are, these projects are fun!
    =Chemilizer
  10. lifespeed
    lifespeed Member
    Apr 27, 2007
    California
    It sounds like you have a significant iron problem. Unfortunately, while there are many good solutions to iron that may be tailored to your specific situation, you will not find a *true* solution for cheap. I would estimate $1 - $1.5K.
  11. OldBat
    OldBat New Member
    Jun 20, 2013
    North Georgia
    Bumping my original thread because the new one got derailed due to my
    misremember some advice from this one. Which one do you recommend?
    They have two adjustable ratio, four fixed and several smaller (cheaper) adjustables that appear to be just the guts to rebuild and or upgrade a fixed to an adjustable.
Similar Threads: Iron pre-filter
Water Softener Forum, Questions and Answers Best Water Filter for Low amounts of Iron, Magnesium, and Manganese Yesterday at 10:28 AM
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Sunday at 12:24 PM
Water Softener Forum, Questions and Answers Iron threshold for dedicated filter Feb 5, 2017
Water Softener Forum, Questions and Answers Lots of iron. Best whole house and best pitcher filter Feb 3, 2017
Water Softener Forum, Questions and Answers Redoing water plant - Iron treatment and water softener suggestions Jan 27, 2017
