Intake piping on bottom of lake
Discussion in 'Irrigation / Sprinkler Forum' started by bassadict69, Sep 3, 2013.
  1. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    I am ready to permanently run the intake plumbing to an irrigation pump on our dock. How should I run this and how should I hold it down on bottom.
    I am thinking that I will come off the pump intake, down into the lake and down to the bottom then run the piping through several cinder blocks spaced one per 10ft or so until I get it out to deeper and weed free water, then put the foot valve.
    Also, is some sort of filter recommended over the foot valve?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If you plan a permanent fixed suction line to a pump, you might do with a check valve at the pump intake, rather than a foot valve. That approach also gives you some freedom to choose an intake strainer/screen that fits your system and sprinkler heads, in the event that they want cleaner water.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Some folk use a sandpoint and a checkvalve instead of a footvalve.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I use 2" pvc about 3 foot long with 1/8 inch holes drilled every 1/2 inch. Then I have a fiber filter over that, that I can rinse easy. It will stay on the bottom when filled with water.
    That keeps fish from getting sucked up and sticking to the inlet.
    However you do it, you will have to clean some type of filter on occasion.
    Good Luck.
  6. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    Thanks guys!
  7. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    Rookie here! LOL! Can you explain sandpoint?
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You need to make sure your area will allow a sandpoint in the lake. It will most likely be in the mud, in your area.
    Some locations do not allow taking water from a lake for irrigation. Temporary is a bit different than permanent.
    Good Luck.
  10. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
  11. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    We have to pay a yearly fee to draw the water, but it is allowed. Most homeowners on the lake pump water from the lake for their irrigation system.
  12. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is good.
    You have more fresh water than we do.
    How big is your pump inlet ?
    Good Luck.
  13. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    intake is 2 inch
  14. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I guess people around you would know how to do it properly.
    It will have to be done in a way to protect fish from sticking to the inlet.
    And keep boat props out of it.
    Have Fun.
  15. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  16. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    Confused? That gets driven into ground/bottom of lake?
  17. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    If you have a sandy bottom, you can shallow bury it horizontally. They also come in metal in many sizes.
  18. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    So it is buried in the sand, mud or whatever is on bottom and still draws water without plugging up?
Similar Threads: Intake piping
Irrigation / Sprinkler Forum PVC joints coming apart on intake piping! Aug 26, 2014
Irrigation / Sprinkler Forum clogged intake or loss of prime Jun 28, 2010
Irrigation / Sprinkler Forum Flower Bed Remote Faucet: what type of piping to use? Oct 24, 2011
Irrigation / Sprinkler Forum Sprinkler Polyethylene Piping: what is lifespan? Nov 2, 2009
