GG_Mass
Hello,
I'm covering the water pipes in my basement with insulation.
At this point I'm doing the area by the main water entry, and that's where some electrical wire is present.
There is one cable that gets in the way, and I want to know if it's Okay to wrap insulation - and by doing that, preventing it from coming with contact with the water pipes.
This cable, essentially goes nowhere, is attached from one side to the plumbing and the other side goes behind the wooden board (see pictures) and hangs in the air.
In image1 you can see the wire - the one that's going left ,
in image2 you can see one of the areas where it touches the pipe, that's where insulation is going to come in, and will separate between the two.
Image3 is where the wire just goes behind the wooden board and hangs there.
Image4 is a general look at the area and the wire can be see going to the left and behind the board.
Thanks for your time .
