Insulating BoilerCopper Pipes
Discussion in 'Boiler Forum' started by molo, Feb 4, 2010.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Are there foam insulation tubes that melt onto the copper pipes? I do not want this to happen. I have a boiler with several feet of exposed 3/4" tubing in the basement and am trying to find the best way to do it.
    Thanks for any replies!
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Use Armoflex.
  4. juror58
    juror58 New Member
    Jan 23, 2010
    Central NY State
    I've insulated my boiler lines with the grey foam insulating tubes from Home Depot. (1/2", 3'4", and 1" lines.) They've been there, unmelted, for nearly 15 years. The temp of those lines never gets above 180, even those coming right out of the boiler.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    The box-store stuff typically only comes in 3/8" wall (~R2) varieties. It's better than nuthin', but 3/4"-1" wall thickness stuff is "worth it" for temps over 130F. Even the cheap stuff can handle temps up to 160-180F, but over 200F a lot of it starts to break down. If you can't find it locally find it online. Grainger sells a pretty good selection, if nobody else in your neigborhood does. Some Ace Hardware stores carry 3/4"-wall stuff.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I'm not saying that insulating is a bad thing and in some locals it is the code. But the truth of the matter is that in an average basement, when you run the numbers, insulating the pipes would take a few hundred years to pay itself back.
  7. dsorkin
    dsorkin New Member
    Jun 2, 2010
    New Jersey
    If there is ever a fire in the house the foam insulation will produce toxic smoke when burned. Fiberglass insulation will not burn.
Similar Threads: Insulating BoilerCopper
Boiler Forum Insulating PEX supply and return in CH system Dec 25, 2016
