Installing extra layer of plywood
Discussion in 'Shower & Bathtub Forum & Blog' started by ehlinn, Feb 9, 2005.
  1. ehlinn
    ehlinn New Member
    Jan 26, 2005
    Maryland
    I need to beef up my existing subfloor before laying cement board and tile. Does anyone have any suggestions regarding the best way to add the second layer of plywood to my subfloor.
    Should I use some sort of adhesive along with screws?
    Thanks
  2. jadnashua
    Adding the same thickness plywood doubles the stiffness. Gluing it increases the stiffness 8x! Depending on the tile you might want to install would depend on whether it is necessary to either just add another layer, or if it can be glued together. If you decide to glue, use something like Titebond II, use a squeegee or something similar to spread it evenly, then use deck screws to put them together. Avoid screwing the second layer into the joists (but make sure the first layer is solidly attached before adding the second). Do not line up joints - overlap them about 4-6" or so. Keep the plywood running across the joists to provide the max stiffness. You should also check the maximum unsupported length of the joists, and their depth and run those numbers through a deflection calculator to ensure you have a stiff enough floor. You need a stiffness factor not only between the joists (provided by additional thickness of the subfloor) but also along the length of the joist which is determined by the length and the depth of the joist. Walls under the floor are good to shorten their effective length. Note, I'm not a pro. There is a deflection calculator over at www.johnbridge.com you can use.
    Also, cement board makes a good substrate to tile to, but adds almost nothing to actual floor stiffness. The instructions for putting down cbu (cementaeous backer unit) call for it to be installed with thinset and the appropriate screws or galvanized roofing nails. Make sure the floor meets the stiffness reqs first, and don't expect the cbu to do it for you.
  4. ehlinn
    ehlinn New Member
    Jan 26, 2005
    Maryland
    Thanks. Why is it important not to screw the second layer into the joists?
  5. jadnashua
    The goal is to make the floor stiffer, but, to also still allow for independent expansion/contraction of the subfloor materials. If you attach the second layer to the joists, then it isn't independent. Now, if you are going to glue them together, some of this is a mute point, but, you still want to offset the end and side joints, since bridging them makes the floor stronger - i.e., you don't want the edge joints to align vertically between the panels.
  6. ehlinn
    ehlinn New Member
    Jan 26, 2005
    Maryland
    That makes sense. Thanks again.
    Eric
Similar Threads: Installing extra
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Saturday at 2:13 PM
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
