Installation of a water source heat pump
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by budwiser, Aug 30, 2011.
  1. budwiser
    budwiser New Member
    Aug 30, 2011
    I am considering to install a water source heat pump'
    my house is a single floor bungalow of 2300 sq. feet
    with a non finished basement.
    the well is 100 ft .from the house at 130 ft. deep 6" casing.
    the pump is set at 125 ft. and is a flowteck 1/2 hp.
    the water temp. coming into the house is 54deg.f.
    When I had installed the well pump I let it run with A 100 FT. of supply line open for seven days straight and it never ran short of water.
    The supply line is 1" pvc.
    When installed I put in a return line to the well of 1/2 pvc.
    What size water source heat pump would I require for this size house,
    Would it run off the plumbing and well I have now, or would a seperate new well be required
    If possible what brand name would you suggest if possible.
Similar Threads: Installation water
Plumbing Forum, Professional & DIY Advice Hot Water Tank Installation Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Taco On Command hot water recirc pump installation gone kind of wrong... Jul 26, 2015
Plumbing Forum, Professional & DIY Advice New water heater standards and attic installation Apr 8, 2015
Plumbing Forum, Professional & DIY Advice Water softener installation problem Jul 18, 2014
Plumbing Forum, Professional & DIY Advice Planning for installation of hot water recirculator May 2, 2014
