Sorry for the long post but here it goes - any help is greatly appreciated.
Little background first:
We recently (2yrs ago) converted out heating from oil/steam to gas/hot water. My house is 4 stories - 18'x34', (basement, 1st floor,2nd, & finished attic) and is attached on both sides. I sized up the system with heat loss calculations myself and with the help of some people here. I had a Williamson GWA-070 boiler installed and we did cast iron sun rad radiators throughout, and the house heats up very nicely.
The DHW is an indirect Burnham stone lined 40gal from the previous owner - probably about 6 yrs old fed off the new boiler. In sizing up the boiler I didnt pay enough attention to the rate of return on the DHW tank though my plumber said the 70k should be fine. I probably should have gone with the 105k model.
Long short - the DHW works but not for that long on regular use (2 adults and 4 kids). it works OK but will run out of steam. We recently installed a 4th bathroom in the attic so we now have 3.5 baths. Typical use durring bath time is 2 showers + a bathtub. When running 2 showers shortly after having filled a bathtub there is no hot water left.
Is there anyway (now that I already installed a new boiler) to squeeze more hot water out of the system or to speed up the recovery rate.
I changed the shower head in the basement to a low flow but the ones on the 2nd and and attic dont have enough pressure to work with the low flow heads. I am planning on changing the DHW pump to get better pressure on the other floors when the other showers are running. I raised the temp on the DHW tank to 140, and the boiler to 190 (a bit high).
Is there anything else I can do to get more hot water. I understand that raising the temp of incoming water will also speed up recovery rates but I dont see a good option for that here.
Your help and advice is greatly appreciated.
Mark
Mark
