Bluebinky
It is NOT the job of an inspector to QA the workmanship. Bottom line is it either passes a pressure test or it doesn't. He will try to find obvious code violations, but will NOT have the opportunity to inspect every joint visually. It would be unusual for an inspector to fail a job on quality of craftmanship unless there it was a SERIOUS mess. There aren't enough inspectors, you couldn't afford it if they did inspect like that, it would get over into an area that is WAY too subjective. A first year apprentice may do a pipe job that does not look as pretty as a 20 year journeyman would put together...but if the joints are sound, that is what counts. The construction industry perforce accepts a certain variability in workmanship. We could argue about this all day!
I agree, but it's pretty scary to me. No plan check, no license, no 15 minute leak-down check, and I could have done 99% of it using PVC or whatever and it would have passed with the bad fitting that I only noticed because it was leaking less than 1/2 psi per *day*...
Don't want to give advice about gas work, but I can't help saying that -- as for what size pipe to use, read (and re-read) and understand the appropriate code...it will tell you how to figure it out.
