handyman2011
Both have Kohler showers with a diverter within the tub faucet.
Here is the issue
- The hot water range in the tub valve is very small, turn the faucet to max hot water then back it off counterclockwise about a 5-7 degree and you're in the cold water range. Imagine a clock and the hot water range only being between 11 - 12 oclock (if at that) when I feel it should go at least from 9 - 12 oclock.
Will replacing the cartridge help this problem?
Any advice to what could be causing these issues is much appreciated.
Here is the issue
