in well pump 200 feet down is splitting my pvc pipe
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by speedyt, Dec 30, 2012.
  1. speedyt
    speedyt New Member
    Dec 30, 2012
    missanabie ontario
    I have recently come across this problem where The Pvc pipe is being split like there was high pressure. Ive used this well for many years with no problems. In the last 3 months Ive had to pull the pump out cause I lost water do to this strange accurance with the pipe being split like as if it had been stretched and bursted. The burst on the pipe is up about 1-2 feet from the pump. Again this is an in well pump 200 feet down. Thanks for your help and replies.
    kind regards,
    stephan
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I see a few of these a year.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    My guess is that you have more than one checkvalve and that is causing water hammer.
  5. speedyt
    speedyt New Member
    Dec 30, 2012
    missanabie ontario
    oh. I never heard of water hammer expession, but defenetly something to look into. Thanks
  6. speedyt
    speedyt New Member
    Dec 30, 2012
    missanabie ontario
    it expands like this on the black pvc pipe at the bottom of the well. Above the threads tho. 1 foot above the pump. Do you think its the pipe or the pump doing something strange
  7. craigpump
    Apr 12, 2012
    If the pipe is swelled, I would say that the pump is running dry and turning what little water there is into steam which is then swelling the pipe.
    I would do a simple yield test to find out how much water your well is making.
  8. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Holy Schneikei!!
    How does that happen?
  9. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    We see this all the time. In our area most people don't think it is cold enough to need a pitless adapter. So the well head freezes, the water can't get to the pressure tank, water in the pump heats up, swells the pipe, and the pump falls off. It can also happen if you pump the well dry as Craig says. It can also happen if the nipple to the pressure switch is clogged, have a hole in the pipe, or the pressure switch doesn't shut off the pump as it should.
    If the pipe were not swelling I would agree with LL, as a split can also be caused by having too many check valves.
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I missed the part about the pipe swelling. The OP did not mention the type of pump. If it is one of those VFD types, they can make some crazy pressures fast when they mess up.
  11. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    I've seen my fair share melt off over the years , but never seen one bubble pvc like that.
  12. craigpump
    Apr 12, 2012
    This one was on a Sub Drive 100..... The first one on a 1 hp with a QD pump tek.
    This is what happens when the pumps run long enough to create steam in a weak well. In both cases the wet ends were wiped right out.
    Valveman, both of these jobs had pitless adapters buried 4+ feet.
    Pretty damn amazing
  13. speedyt
    speedyt New Member
    Dec 30, 2012
    missanabie ontario
    yupp. Same thing happened again , pipe swelled and bursted just like this picture. yesterday was not a good day at -20 pulling the pump outta the 250 foot well. Thanks for great information. We now lowered the pump an xtra 50 -60 feet down. hopefully it all is good.
Similar Threads: pump feet
Pumps and Tanks Well Forum & Blog. Water is life. Sizing a pipe from pump to house 250 feet apart Oct 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How to pick up motor and pump set drop in 350 feet well? Aug 10, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pumping water up from 32 feet Sep 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Do 200 feet of water above the 1.5 HP pump help the pump push 540 feet head up? Apr 17, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Suitable water pump to draw water from 35 feet(10 meters)to 50 feet (20 meters)well. Jan 4, 2008
