IX filter for Arsenic and Nitrates
Hi All:
I have gained enough information in the last few weeks to result in my sending the unopened Aquasana whole house well filter back to the sender. I am going to use clack and fiberglass tanks, with a water softener, followed by an Ion Exchange resin to get rid of my elevated As and NO3 and then a UV Max D4.
A few questions:
1) Can/should I mix an Arsenx resin and NO3 type II resin in the same tank, i.e. topdress with Arsenx and use them to get rid of both As and NO3? Is that the best approach? Can I mix a NO3 selective resin with Arsenx and not worry much about dumping? Can I get rid of Arsenic and NO3 using just one media?
2) Do these filters reduce the influent by a percentage, i.e. the effluent levels will be some percentage of the influent, or do they reduce to a certain level. My NO3 is 11 and my As is .006. I don't have that much to go to get my levels pretty low- can I expect them to be not detectable after the filter?
3) In terms of dumping the nitrate or Arsenic, can I be comfortable that if I regenerate frequently enough I will not have a problem with dumping?
4) I can easily monitor NO3 levels with a test stick, but Arsenic is more difficult. Will the NO3 dump first and serve as the "canary in the coal mine", or is it possible I could dump Arsenic and not be aware of it?
I read a few published studies of combined As/NO3 filtration from cities that had hired Kinetico to filter their municipal wells, and the data reported while they were tuning their system showed very large surges in the levels towards the end of a run. I was also unimpressed with the absolute reductions seen, something along the lines of 15 mg/dl of Nitrate going in, and then 7 mg/dl coming out. Is that typical for these filters?
Thanks
Peter
Hi All:
A few questions:
Thanks
Peter
