Identifying Knob & Tube Wiring
Discussion in 'Electrical Forum discussion & Blog' started by chuck_r, Oct 24, 2007.
  1. chuck_r
    chuck_r New Member
    Jun 22, 2006
    We're thinking of buying a two-story house built in 1940 which has a little knob and tube wiring in the basement, but most of the visible wiring is romex-type cable (there have been a lot of additions and modifications to the house after it was built). It has a 100 amp main breaker panel with breakers, not fuses, and there's only romex-type cable coming from the panel. The current owners (not the original owners) don't know how much knob and tube wiring is in the oldest part of the house, or whether it was ever replaced. The insurance company we want to use, USAA, says it won't insure the house if there is any "active" knob and tube wiring anywhere in it.
    Is there an easy way to tell how much active knob and tube wiring is behind the walls, in the ceiling, etc., without cutting holes in the plaster? Unfortunately the attic above the original part of the house is floored, so we can't easily examine the second story ceiling.
    I was wondering whether one could take the cover plates off switches and outlets and examine the wiring coming into the boxes and reliably tell whether it was supplied by knob and tube wiring.
    Thanks
  2. Ian Gills
    Jul 24, 2007
    USA
    If you are allowed to do it then your suggestion will probably be the best way.
    I think your concern is justified. There is chance that the more modern wiring has been installed in the more accessible areas and then just tied up to old wiring in the inaccessible ones. Definitely worth a check if you or a qualified electrician are allowed to do so.
    I wonder if it might also be worth checking for ground on the receptacles? If they are all two-prong then this might be an indication that there is old wire servicing them. An open ground on a three-prong receptacle would also raise my suspicions. Similarly if you see three-prong GFCI receptacles everywhere (not just around water areas) then this might be another give-away.
    What do the pros say?
  4. chuck_r
    chuck_r New Member
    Jun 22, 2006
    Can someone describe what I'd look for in the boxes to identify Knob & Tube?
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Do the smart thing before buying a home.
    Hire a Home Inspector to evaluate the home for hidded flaws in all the aspects of home building.
    If the house is over 60 years old there could be more to worry about than knob and tube wiring.
  6. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    jw,
    I kind of disagree with you. While I think most non-knowledgeable people are wise to get an inspector I don't think most are worth thier cost.
    My buddy recently bought a house and the inspector didn't note or say anything about the electrics just dropping down from the joist with no conduit and the lack of a wiring clamp going into the water heater. In addition the inspector missed the fact that front of the tank was rusting indicating a leak. Also didn't make any notes about the lack of sealing on the duct work. The inspector also failed to confirm that all electrical was working etc..
    Tom
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    A Knob and Tube installation was addressed in the 1971 cycle as circuit extensions only.
    This rule remains in effect through the 2005 cycle and is unchanged for the 2008 cycle page 236 of the 2008 NEC
    The 1968 cycle allowed the installation of Knob and Tube wiring in a new installation, Article 324 section 324-2 use page 116 of that NEC.
    When seeking a good Home Inspector I recommend using this site and clicking on the information found in the top left corner of the web page.
  8. statjunk
    Jun 28, 2007
    Great link. Thanks
    Tom
  9. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    First clue: No ground.
    Second clue: All wires are black.
    Third clue: Wires enter box with a thick fiber-like sheath, called loom, around it.
  10. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    Sounds like an unreasonable burden being placed on you by the insurance company. You will have a damn hard time verifying that there is no knob and tube active anywhere in the house. I did not realize it was still in use in the 40's. A knowledeable inspector is necessary here.
    some external indicators could be:
    knob and tube visibly coming out of the fusebox. :)rolleyes:)
    bakelite surface mount baseboard receptacles
    bakelite surface mount switches
    ceiling lights that turn on only by pullchain
    all indicators of a very old electrical retrofit.
    the invasive approach means looking at the wires entering boxes. Individual, black cotton covered wires means knob and tube is used.
Similar Threads: Identifying Knob
Electrical Forum discussion & Blog need help identifying a tool Apr 29, 2008
Electrical Forum discussion & Blog Trace knob and tube circuits Dec 30, 2015
Electrical Forum discussion & Blog a single 3-way switch controlling a light fixture on a knob & tube circuit - why? Jun 12, 2014
Electrical Forum discussion & Blog knob & tube question Feb 10, 2009
Electrical Forum discussion & Blog Old Knob and tube removal Feb 21, 2008
