Idea: a water cutoff if conventional pressure tank going dry?
It's probably been done, but suppose you had a conventional pressure tank with an exit cutoff that would stop the water if air was about to blow out?
This could permit a lower positioning of the air release valve.
This type of system would provide aeration, which could be useful in a following catalytic filter. A variation would raise the exit a bit, and have a drain valve to drain solids that might fall out.
While it also avoids a bladder that can fail, it introduces 3 things that can fail.
Comments?
