I need help cleaning the hot water coil in my oil fired furnace.
Discussion in 'HVAC Heating & Cooling' started by Mad Plumber, Jun 3, 2010.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    Please send me a link on DYI to clean this coil. Is there a kit? Where can I get it? Is it a difficult process? Our hot water pressure has rapidly decreased over the past 6 months and we were told it is the residue build up on the coil to the fault of our water company however we cannot find anyone to clean it....our furnace is only 5 years old!!! I am not prepared to settle for the lack of pressure.
    Thanks so much,
    Doreen
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    If it has scaled up in under 5 years that's usually an indication of water-hardness. An acid flush may solve it temporarily, but it's likely to scale up even more quickly the second time around. A better investment (but more money, for sure) would be to spend the money on an indirect-fired tank HW heater and a water softening system. An indirect will run higher efficiency too, since you can let the boiler cold-start, and the tank has far better insulation & capacity, and you can run it at lower temp than the boiler for lower standby loss. (Oil is expensive, and embedded coils are about the least-efficient legal way to heat hot water when it's not an active heating season.)
    An acid flush requires a small acid-proof pump & tubing, breaking the system open, recirculating the acid solution through the coil for some period of time (which will vary with scale thickness & type) then rinsing it for a half hour or so running fresh water through it with the pump. Sometimes white-vinegar is adequate, but otherwise buy a gallon of purpose-designed descalers, which are sligthtly more acidic. Don't try mixing your own out of muriatic acid, or suphuric acic etc (unless you have a degree in chemistry and can live with the results of an error.)
Similar Threads: need help
HVAC Heating & Cooling Looking to buy 2 stage 17 seer AC Need Help Jul 5, 2016
HVAC Heating & Cooling nordyne air handler.need help wiring it Aug 30, 2015
HVAC Heating & Cooling r22 for central air need help Aug 16, 2015
HVAC Heating & Cooling Need Blower Design Help for Wood-Burning Stove Dec 20, 2014
HVAC Heating & Cooling terms in a hot water heating system and help needed on wiring Nov 6, 2014
