I have 3 zones that are not working...
Discussion in 'Irrigation / Sprinkler Forum' started by mayhem5220, Sep 6, 2006.
  1. mayhem5220
    mayhem5220 New Member
    Sep 6, 2006
    I have 8 total. Each is set to come on for 10 minutes then repeat. Zone 1-4 work normally. However, zone 5-7 do not come one. They system thinks they are on and gives each one it's ten minutes. Then zone 8 comes on to close the program.
    Does anyone have any idea why these 3 zones are not coming on?
    Thanks in advance.
  2. prashster
    prashster New Member
    Dec 7, 2005
    I'd start by inspecting the valves. It's more likely that there are multiple bad valve connections or faulty / dirty valves than it is that you'd have 3 simultaneous leaks in the different lines that were so bad that you'd get NO pressure out of any of the zones.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Check the electrical wiring, both the hot and the ground wires. Usually the ground wire is daisy chained and a break in the chain would cause the problem.
  5. hj
    zones
    You could have broken valves, although it would be unusual for three in sequence to break at the same time. You also have to check the electrical connections, and also check if the power is reaching the solenoids. If the solenoids operate, then you have bad valves.
Similar Threads: zones working
Irrigation / Sprinkler Forum 6 Zones - 1 not working Apr 13, 2009
Irrigation / Sprinkler Forum 6 zones and 2 are not working Mar 17, 2009
Irrigation / Sprinkler Forum 2 of 6 zones not working Apr 16, 2008
Irrigation / Sprinkler Forum Zones not working - Where are the valves? Sep 3, 2007
Irrigation / Sprinkler Forum Four zones not working since startup Jun 23, 2007
