I failed my 'pre-glue' inspection...
Discussion in 'Shower & Bathtub Forum & Blog' started by gregsul, Dec 20, 2004.
  1. gregsul
    gregsul New Member
    Dec 20, 2004
    ...now I humbly ask for advice. My vent/drain arrangement wasn't acceptable for the shower or tub in my bathroom renovation - vents on the wrong side of the trap arm, use of a san-tee on it's back - basically, it was defined by the inspector as 'line venting', and not legal. (He had a few other words for my setup but I won't share them here...:) He offered to do one more 'pre-glue', but made it obvious that I'd better have my ducks in a row next time. So, I'm enclosing a .jpg photo of the latest abs dwv layout I'm hoping to assemble in the next few days. I connected everything up to the lav and stack setup (which passed) and am mainly want to know if the traps and vents seem to be laid out properly. The short (3 ft.) vertical pipes represent the vents. The shower vent shown in the photo is a 2 inch pipe, because that's what I had on hand when I set this up earlier today. I have since purchased a 2x1.5x2 long turn combo so I can vent with 1.5 inch pipe. This will all be installed in my basement under the bathroom. Any thoughts? Thanks for any help you can send to a diy newbie.
  2. hj
    pipe
    It looks proper, but what is a "pre-glue" inspection? Do you put it all together, get an inspection, and then glue it together in the location where it goes? If so, I hope there is a second inspection with a pressure test to ensure that there are no leaks.
  4. gregsul
    gregsul New Member
    Dec 20, 2004
    A "pre-glue inspection" is...
    In Seattle, a "pre-glue inspection" is an optional inspection advised for homeowners who don't have the experience a professional plumber brings to the job. Generally, you install the pipes but do not glue them. That's what I did for the inspection, but when I needed to start over I arranged everything outside to figure it out and photograph it. Once the pre-glue inspection is passed the pipes are glued and tested. The water supply is installed and tested. Then the "rough-in" inspection checks all of that. I'm guessing the final inspection happens after all the fixtures are connected, drywall & tile installed, etc. Thanks for checking this out - I'm relieved to know that I'm moving in the right direction.
Similar Threads: failed 'pre-glue'
Shower & Bathtub Forum & Blog Help - Major Damage from Failed Shower Pan Oct 18, 2009
Shower & Bathtub Forum & Blog Failed joint at shower head Jul 6, 2008
Shower & Bathtub Forum & Blog My PVC Membrane Leak Test Failed Mar 20, 2008
Shower & Bathtub Forum & Blog Symmons Type B, failed attempt Jul 6, 2005
