cdub2288
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I have an apartment that is about 40 years old with an old bathtub in it, that is made of either porcelain or ceramic. It is an ugly orange color, so I am repainting it White using a kit I purchased at Home Depot. However, the bath fittings are all worn out, so I also need to replace them. The only thing I have not been able to accomplish so far is taking out the tub drain insert . I've already taken out the stopper that goes up and down, so there is just the metal insert in the tub left. The drain insert has no cross section like all the newer models, so I can't use pliers or the special cross section tool to take it out. I'm not sure how to remove it. I tried using a small 10 inch faucet wrench from home depot to grip the top and bottom (The Wrench ) but I couldn't fit the wrench into the drain. Maybe i need to find a tool that can grip the inner sides of the drain insert? or find a wrench similar to the faucet wrench that can grip the bottom and top of the drain insert to turn it? The bottom of the current drain is exposed. I read an article where someone with a 40 year old drain just made a cut in the drain and pulled it out. If it comes down to that, is that a safe way? And also, are all tub drain spouts threaded? I'm not sure if the old designs are different. And would this possibly require going under or in the walls beside the tubs? Because this is an apartment and that would be quite difficult to do. I tried having the tub replaced, but even the plumber said it wasn't worth it and that he would have to knock down the ceiling below the unit to put in a new tub. Hopefully the same thing doesn't go for replacing a drain. The new tub drain i am using is the kind that you just turn to lock, so there is no need to connect it to the metal plate on the side of the tub that controlled the old stopped (I'm just covering it up with a blank plate). I just need to install the new drain in. Thanks
-Chris
"EDIT" I was searching online and found this tool by rigid. Does anyone know if this would work? It looks like it can grip the insides of the drain. BASICALLY, are all bathtub drains threaded? I dont want to remove this drain only to find out the tub isn't threaded and i will be totally screwed over.
-Chris
