How useful will my well be for irrigation?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tbeaulieu, Jun 14, 2009.
  1. tbeaulieu
    tbeaulieu New Member
    Jun 13, 2009
    Methuen, Massachusetts
    After much trial and tribulation, I've finally been able to pull water from my shallow brick well (15 feet deep, about 8.5 feet of standing water).
    I ran the pump last night for 4 hours, drowing my wife's flower bed. She wasn't as excited as I was. It pretty much emptied the well. It was late and I could see the footer valve just below the surface, so I stopped the test. I'd say there was another 1 to 2 feet of water left.
    The (unscientific) results are in...
    10 GPM for 4 hours.
    20 minutes = 1 foot of water drop.
    The total drop was about 7 feet.
    This morning I checked the well after it rested for 7.5 hours. It regained 5 feet, or approximately 1,000 gallons.
    I had hoped for a better recovery, but I have no idea what a typical irrigation system even uses for volume. I have one acre, including the house. Of course, much of that won't need watering. My dream is to have sprinklers for the front yard, at least, and soakers/sprayers for the planting areas.
    I'd love to hear any thoughts on how "well" my well might serve me, given the numbers from the test.
  2. tbeaulieu
    Jun 13, 2009
    SO 12 hours later, the water level's back up to normal. So the well recovered in somewhere between 7 - 12 hours.
    I know it would be much better to have a well that could supply x GPM w/o going down, but hopefully this will serve some purpose with the right zoning and scheduling.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    You're OK to irrigate!
    I would just suggest that you install a low pressure switch to shut the pump down in case of pressure loss or better yet install a Cycle Sensor by www.cyclestopvalves.com. You can purchase it online!
    Porky
  5. tbeaulieu
    Jun 13, 2009
    I've done some reading today and, unless I'm messing this up, I'm starting to suspect this well won't be able to support irrigation of any meaningful use. This is depressing.
    The largest part of my lawn (12,600 sq-ft) would require 8,112 gallons of water for 1" of coverage. (1" = 624 gallons for 1,000 sq-ft, so 13 * 624 = 8,112).
    Roughly, the volume of my cistern (15' deep by 63" wide brick well with a water table of 7'). This comes out to 1,134 gallons, I believe. We're talking rough numbers, but my output test is about 300 gallons off. I asume that's because the well was replenishing during the draw down test.
    So, what's my point? Well, how on earth can I water a lawn that needs 8,100 gallons of water, with a well that produces 1,400 in 24 hours?
    So very sad.
  6. andy_007
    andy_007 New Member
    May 14, 2008
    Not ideal, but as you had said, with the right zoning and scheduling it would work.
    You don't need to put 1" of water on you lawn each time you water.
Similar Threads: useful irrigation
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation system with 25 HP build Nov 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure issue with irrigation and home Aug 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. CSV on Irrigation Well Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How to get water in to bladderless pressurized irrigation tank? Jun 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump not working May 28, 2016
