How to set drain for basement bathtub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tdanna14, May 17, 2006.
  1. tdanna14
    tdanna14 New Member
    May 17, 2006
    I'm installing a bathtub in my basement. I have the drains laid out but have a few questions:
    1) I have an 'access pit' setup right now to connect the tub drain to the house drain. Do I need to leave that accessible or can I fill in the whole pit (i.e. covering the j-trap and all) w/concrete? If I don't fill it, how do I make sure no ground water seeps up?
    2) I need to use a studor vent for the bathroom since I can't tie into the roof vent. How high do I need to place that above the vanity drain. Can I simply put it under the vanity cabinent?
    Thanks in advance for any assistance!
  2. prashster
    prashster New Member
    Dec 7, 2005
    Code may require that you fill in the 'access pit' because of radon gas.
    As far as ground water seepage, the concrete won't prevent a rising water table. The plastic sheet under the foundation (assuming you have one) is to inhibit water vapor. But rising water will come around and through the barrier and up thru the floor, regardless of what's there. If you ever have a water problem, you have to fix it with a sump or improving your land's drainage.
    I know some places admit the use of a studor or other type of air admittance valve for bar sinks or islands - but I am not sure they're permissible for tubs and toilets. Check w/bldg offc, since this'll be specific to yr municipality.
  4. tdanna14
    tdanna14 New Member
    May 17, 2006
    Thanks for your reply!
Similar Threads: drain basement
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
Plumbing Forum, Professional & DIY Advice 4" Storm Drain into Basement... Oct 9, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Help with basement drain Sep 15, 2016
