How to manually prime a 1985 Jacuzzi Pump model 5RP2?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by MJBC, Mar 11, 2010.
  1. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    Hi, this is my first post to the forum. The pump motor is running but won't turn off. There is no pressure registering on the meter. Someone told me to prime the pump but I don't see any obvious ways to do that.
    This pump is used for well water. There is a red cylinder connected to the pump but the only name on this object is "H20 To" Pre-charged water tank system.
    Any help is most appreciated. Thank you.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    See the plug in the top of the pump, right beside the gauge. Not the big one, the one beside that. ( there probably isn't a big one on your pump because thats where the discharge pipe goes) You take that off and fill the pump with water. Put the plug back in and turn it on.
  4. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    Thank you! I'm totally impressed that you have a snapshot of the pump. I looked all over for one online.
    I'm not completely sure that's the problem but think I should try first. We unplugged the pump when it started running non-stop. Is there any electrical risk to just plug it back in once I fill the tank? Also, we plugged the pump back in but the gauge did not register - at all...do I have to reset it or something once I turn it back on?
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If it lost it's prime there is usually a reason. Either the foot valve is bad (very likely) or there is a leak in the suction line. There is no re-set and yes, plug it back in after you fill it.
  6. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    hmmmm - I'll let you know what happens.
  7. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    Thank you very much for your help Mr. Griffin. You saved me a whole heap of grief and probably saved a whole lot more in cost. All it needed was priming.
  8. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    Lost Prime again
    Hello Sir. Well the pump lost the prime again and it won't come back. So I'm thinking it's as you said that the foot valve is bad. Since the pump is so old (1985) is it better just to replace the whole thing or do you think I might be able to save some money and just replace the foot valve?
    If I were to replace the whole pump, do have a guesstimate on the cost for the new pump and installation> (e.g. are you allowed to make recommendations on the make or model we might want to consider?)
    Many thanks in advance for your advise!
  9. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Apparently there was nothing wrong with the brand you have. I think that part of Jacuzzi is now owned by Franklin Electric. Most major brand name pumps will be just as good. Sta-Rite, Meyers, Goulds, AY McDonand, Flint & Walling just to name a few.
  10. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    Jacuzzi Pump
    Thank you for your reply. We have a plumber out here now and he replaced the old pump but it's still not working. Now he thinks the well is dry but we just had 3 big storms (down-pours....) before we commit to a new well too, do you have any suggestions?
  11. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    What is the suction line - this is sounding more like the problem...
  12. valveman
    Mar 15, 2006
    Lubbock, Texas
    The suction line is the pipe between the pump and the bottom of the well.
  13. MJBC
    MJBC New Member
    Mar 11, 2010
    Virginia Beach
    It seems like this is a big roll of the dice. The plumber said you can install a new well but it might not hit water. As in you can't really tell where the problem is - kind of hit or miss. :(
    (i.e. maybe the water table changed or is too low.) I don't know what to do. I don't want to pay $800.00 for a new well and a new pump.
    Guess this one will need to be put on hold. Thanks so much for your replies.
Similar Threads: manually prime
Pumps and Tanks Well Forum & Blog. Water is life. Well pump only works when manually turned on Apr 25, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well pump only runs when I hold switch manually Dec 7, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Pump won't start except manually...briefly May 12, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Pump keeps loosing prime, lots of air Oct 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump sounds like its not primed but has water at priming hole Jul 18, 2016
