how to level an EXISTING cast iron tub
Discussion in 'Shower & Bathtub Forum & Blog' started by bbillcee, Jan 9, 2011.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    we have gutted the bathroom ( we are having the tub reglazed) and the ledger board that the cast iron tub rests on seems to be rotted out, i dont want to remove the tub because a mud job was put in after the tub and dont wanna mess it up
    the wall side of the tub has dropped about 3/4 of an inch
    i was kinda of thinking to lift that side of the tub a bit and wedging wood between the tub and the studs to keep it level....just want to know if u guys know a easier solution, i dunno if my idea would even work
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    For your tub to drop like that, you would have to have some serious rot going on there...and shimming the tub is a bandaid fix. A cast iron tub is a heavy beast and you need to support it properly.
  4. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    I have to agree with "basement_Lurker" a lot of those cast iron tube should be supported by a ledger board AND wedges under the feet built in on the bottom of the tub, you may have major rot under the tub
  5. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    who usually installs the tub? the plumber or carpenter?
  6. shacko
    Jan 22, 2006
    Rosedale, Md
    Most of the time it is the plumber
  7. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If you are pulling the tub you are better off putting in a new cast iron tub than reglazing what you have, the finish is much better and last a heck of a lot longer. It sounds like your project is growing on you and the new tub may seem like another ratchet up in size, but what you don't want to do is get done and not have the finish last.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I sounds like you will have to do a lot more than you were planning on. You have a rot problem and unless you demo enough of the wall and floor to be sure all the rot is removed, you will continue to have problems. It isn't a matter of what you want to do, it's what you have to do.
Similar Threads: level EXISTING
Shower & Bathtub Forum & Blog New tub level, but doesnt drain water all the way Nov 14, 2016
Shower & Bathtub Forum & Blog Second Floor Tub Leaking Into Main Level Bathroom May 3, 2016
Shower & Bathtub Forum & Blog Bathtub leveling with mortar - Minimum thickness? Apr 18, 2016
Shower & Bathtub Forum & Blog Unlevel tub install Apr 12, 2016
Shower & Bathtub Forum & Blog Bathtub levelling conceptual error Oct 25, 2015
