How to extend a CO?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DavidTu, Jan 30, 2011.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    I have a 45-deg Wye with a CO glued on at bottom of a drop.... problem is a new wall was added behind CO that makes access difficult. What I want to do now is extend the CO back to the face of the wall so access will be from other side of the wall. Can I do this simply by screwing in a male threaded adapter into the CO and gluing pipe and new CO onto that?
  2. hj
    If that will do what you want, the yes, assuming it is NOT a 3 1/2" cast iron cleanout.
  4. dugfresh
    dugfresh New Member
    Jan 31, 2011
    Seattle, WA
    You will want to make sure that you use long turn radius fittings for any extension. Make sure also that the clean out at your final finished wall isn't tighter than the one that is buried.
  5. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    No, but I do have another 3.5" CI CO elsewhere... I thought my building sewer CI pipe was 3" ... but I measured the floor CO to 3.5" as you suggest... does that mean my building sewer is really 3.5" or 4" or what? I sized my vents assuming it was 3"! Am I in trouble?!?
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Your building sewer can be either 3or 4in., the c.o.s were made in off breed sizes to stop people from attaching pipe to them
Similar Threads: extend
Plumbing Forum, Professional & DIY Advice Remove/replace/extend closet ring Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Can sediment trap extend inside wall? Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Extending cast iron drain line for pedestal sink Nov 25, 2016
Plumbing Forum, Professional & DIY Advice How to extend 4" Main DWV when there is no room on the existing pipe Oct 9, 2016
Plumbing Forum, Professional & DIY Advice Moving shower drain (extending) approx. 30" - Any considerations? Sep 26, 2016
