How to determine which is faulty? CB or Pump?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Propwash, Nov 29, 2005.
  1. Propwash
    Propwash New Member
    Nov 29, 2005
    Wife called today to say we have no water pressure, so when I got home from work, I checked the pressure valve as it has been known to attract ants and dirty the contacts. No problem there today. I checked the AC at the control box and I'm reading clean 230V. If I turn off the breaker and wait a few minutes and then turn it back on, I see the meter run for just a second or so and then it shuts off. The pump never turns on. I can only presume that this few seconds is charging the capacitor for start, but I could be wrong.
    The control box is the familiar Franklin Electric 208 108 49, and I can only presume that the submersible pump is a 1HP .75 kw 3-wire. Unfortunately, I inherited this setup from my father and he has since passed, so I have nothing to go on.
    So, I could very easily replace the control box and keep my fingers crossed, but is there a chance that the motor is gone? I'm sure its over 15 years old. How could I determine where the problem is exactly?
  2. Propwash
    Propwash New Member
    Nov 29, 2005
    That's what good neighbors are for!
    I no sooner finished my first post when I got a call from my neighbor asking if I had any luck with the well and when I told him what I thought the problem was, he quickly chimed in saying he had a spare (though only 1/2 hp) control box available, so we quickly swapped mine out and bing! I'm back in business. I'll be going out tomorrow to find a more suitable box, but for the time being... Yahoo!
  4. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    There really isn’t a more suitable box. The control boxes match the horsepower of your pump. You can use a larger hp box on a smaller hp motor, but it does not improve the service life. Follow this link for more control box information and troubleshooting.
    FE Sub Manual
  5. Propwash
    Propwash New Member
    Nov 29, 2005
    Sorry, I guess I wasn't clear enough. The motor is most likely a 1HP motor, since the faulty control box was a 1HP, and as you said, there really was no need to put a more "powerful" control box in in the first place. And since all I had last night was a 1/2 HP box, I've really overrated that box now.
Similar Threads: determine faulty
Pumps and Tanks Well Forum & Blog. Water is life. Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Trying to Determine Pump Mfgr Sep 24, 2011
Pumps and Tanks Well Forum & Blog. Water is life. What Could You Check or Look For To Determine a Dry-Well Pumping Cycle Exists Jan 29, 2010
Pumps and Tanks Well Forum & Blog. Water is life. how do I determine the WELL POINT SCREEN SIZE Oct 12, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Faulty check valve or faulty pump Dec 10, 2013
