How to connect wall hung toilet drain (included) to house drain pipes when only slightly offset from the main stack?
VolcanoGirlDIY
Volcano, Hawaii
Hi,
I'm doing a DIY remodel of my guest bathroom and learning about plumbing for the first time on this project. It's been fun and exciting. I am switching from a regular toilet (i.e. floor mounted) to a wall hung toilet. I have been searching everywhere and cannot seem to find the answer nor a demonstration video on how to connect the vertical outflow/drain from the wall hung toilet assembly kit to the main stack/drain pipes already in my house. All videos and instruction books just show the toilet manufacturer's 3" or 4" drain pipe descending into a hole in the floor, and my question is - what does that connection point look like under the floor? All my pipes are 3" diameter ABS, and the toilet drain provided is 3" ABS. Can someone on this forum help me? Assume I know nothing about plumbing other than everything needs to be vented properly... and the manufacturer's drain that is provided doesn't seem to allow for venting. What am I missing?
Context: Some other information incase it helps.
- I am on post and pier foundation.
- this project started as a way to replace water damage under the tub/toilet area in the subfloor from the previous owner.
- I have the subfloor currently ripped out (new one cut to size) and the pipes are currently easily accessible.
- I plan to build a faux decorative wall that the wall hung toilet will sit in that is 4 or 6 inches deep in front of the main wall for three reasons: added architectural interest to the room, helps me avoid having to reroute the vent stack in the wall, allows for deeper built in shelves above the toilet.
Question: How do I connect these two parts to ensure that the toilet will flush properly/effectively, not cause myself unnecessary clogs, and follow national plumbing code?
Attached is a sketch and some photos of what I have now: a *horizontal* connection angle into the existing main stack from the former toilet (closet flange has been cutoff) and a *vertical* (or could be 45 deg offset) drain out of the toilet that is a part provided by the manufacture Swiss Madison.
What i have sketch.jpgWhat I have photo of drain pipes 1.jpgWhat I have photo of drain pipes 2.jpg
Also attached are 2 options how I can see to connect the pipes - and I'm wondering if one is better/preffered over the other. Specifically the short sweep 90 makes the most sense to me - but is there any regulation on whether than can connect to the wye (san tee?) directly? Every thing I've read has a pipe run (up to 6 ft for 3" ABS) between the 90 and the wye (san tee?)... but is there any reason I can't just connect the two directly together? Note that in the photo I am just holding the pipe "in place" in the perspective of the photo - I have not tried to attach yet. The joist is behind my hand and the pipe in the photo, and the 2x4 in front of the vent piping on the right side is blocking to support the new subfloor - that can be moved/adjusted if needed.
short sweep 90 elbow - my preference but is it ok.jpgPhoto of 90 elbow option.jpg
I prefer the 90 elbow directly in the the Wye (san Tee?) currently installed in my house as that will be easiest to install, and requires no major cutting of my current house pipes nor the vent stack. But the other option is to use the manufacturer's 45 deg offset on the toilet which will allow me to connect to the main stack (and loose the faux wall that I want) as well as the vent stack. This would involve cutting out the current Wye (san tee?) and the Lower part of the vent stack, and connecting as shown. I'll need one more 45 deg 2 in pipe not pictured to connect the vertical vent stack to the pipe layout in the photo.
Any guidance is enormously appreciated. Thank you in advance!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I would use the chosen WC frame location as "king" of the room. Place new WC frame on very solid floor and wall framing and stub drain down. Cut out ABS as appropriate to build to the drain, add a 3 x 2 tee instead of the low heel since the low heel is not to be used in that configuration anyway.
Hope you didn't get a 2x wall WC assembly bc they are a bear to service. Geberit is the absolute best brand, with Toto a distant second.
ABS horizontal pipe must be rigidly supported with ABS hangers.
Elbow under into tee is ok, as would be a wye as you pictured. No impact on performance either way.
wwhitney
Berkeley, CA
Agree with your advice but I don't follow the above. The orientation of the "3x3x2 low heel inlet quarter bend" in the photo is to my understanding the only proper way to use a low heel in drainage. The fitting is effectively a "3x2x3 san-tee".
Cheers, Wayne
VolcanoGirlDIY
Volcano, Hawaii
Thank you both for your prompt replies!
In test fitting the pipes yesterday, I do like the elbow install better but it pushes the toilet farther out into the room that I had intended. Following the above advice to make the toilet location "king"and keep it a little closer to them main wall (while still building pony wall in front to house the carrier), I will definitely need to cut out the low heel. Here are two sketches to make sure I'm following/understanding the 3x2 tee suggestion correctly before I start cutting. The 90+ clean out drawn in the sketch is already part of the plumbing about 1 foot below the low heel.
I have attached two images - mostly the same. I accidentally drew a wye when sketching this out first, so attached are the wye and tee versions - both of which are 3x2 configuration. If this looks appropriate, then I will move forward on cutting out the low heel to keep the tank (in a pony/faux wall) as close to the main wall as possible.
I did get a 2x4 installation wall carrier, but for reasons unbeknownst to me, my house was built in 1979 with 2x3 interior walls - hence the need to build a pony wall "bump out" (secured to the floor and main wall) to install the carrier on the proper stud size.
Thank you again for your feedback and guidance. This is incredibly helpful for me!
John Gayewski
Iowa
Cheers, Wayne
Agreed the vertical 3x2 low heel inlet 90 is only allowed vertical for drainage.
I generally avoid them for drainage all together. No reason for them.
