How to Clean & Sterilize "Whirlpool" style Tub Pipes and Jets ?
Beski
New Jersey
I did a Search here, but didn’t find the info I need.
Last year we bought a house that has a large Tub with Jets (not sure of Mfg). We had the home inspection last March 2012 so the Tub was filled and checked for leaks and the motor was tested, but it has not been used in a year since (although we periodically run the water for a few minutes). Want to use it now, but started to read about the buildup of Bacteria and Bio-Film in the Pipes so not sure what to do next ?
(1) What steps should I take to clean out the pipes ?
(2) What cleaning solutions should I use ? (Bleach?)
(3) How often do we need to clean the pipes ?
(4) As an alternative to cleaning, is there a way to temporarily “plug†the Jets to make it just a Big "Jetless" Tub so that no water goes in or out of the Pipes ?
Thanks,
Tom
Most of the manufacturers have their own specific cleaning procedures. A typical one calls for cleaning monthly. It's a two-step process on those I've looked at. Essentially, you fill the tub, add one chemical, run it to dispurse it throughout the piping, let it sit, drain then repeat with a different chemical. Some of them have a cap you can remove to add the chemicals from above, some you add to the tub basin itself.
I think I've seen 'caps' for the jets as an aftermarket item. No idea if they work, or how well, or if they are model specific, or if I'm remembering correctly!
This type of tub can get pretty nasty if you don't clean it and plan to use it regularly. one reason why many of them are there for looks after the first 6-months or so, people don't want to take the time or spend the money to deal with them.
Personally, I use an air tub...the advantage is that it blowdries itself after use, and since you're not circulating water, crud doesn't get as deep into it. It still takes cleaning, though. I pour in some bleach and dishwasher soap, let sit, cycle it a few times. I do not think this would be sufficient for a water jetted tub, though.
