How to choose a battery back up sump pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Lenn, Jan 18, 2006.
  1. Lenn
    Lenn New Member
    Oct 8, 2005
    I would like to install a good quality battery back up sump pump. The existing sump pump is ½ hp sewage pump connected to a schedule 40 pipe. I have yet to find a battery back up sump pump that has a tee fitting for a schedule 40 pipe. So have resigned myself to just get a good battery back up sump pump and connect it in to the existing schedule 40 line if possible or just run a second line.
    Basically what is a good quality reliable manufacture of back up pumps and what features are needed insure it will work when needed???
  2. Cass
    Cass Plumber
    Nov 12, 2005
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    "I have yet to find a battery back up sump pump that has a tee fitting for a schedule 40 pipe."
    Put a tee in your existing pipe. The arrangement should be as follows:
    Existing pump -> check valve -> tee -> existing pipe to discharge
    Backup pump -> check valve -> into side of tee in existing discharge pipe
    Many battery pumps have lower head capability that AC powered pumps, so be sure you get the head you neet to put the water over the wall.
    Go to www.grainger.com and search on glentronics
Similar Threads: choose battery
Pumps and Tanks Well Forum & Blog. Water is life. Choose a Proper Pump for Specific Conditions Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help choose / source floating level switch for well Jan 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How do I choose shallow well pump size? Sep 9, 2014
Pumps and Tanks Well Forum & Blog. Water is life. How to choose a reasonably good quality submersible pump? Jan 28, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Chooseing a pressure tank Jul 18, 2011
