How problematic is water temperature above 140°F in PVC pipe?
Brandon Weiss
Santa Cruz, California
Okay so I’m using PVC pipe for the drainage in our house and I’ve got this steam oven which gets plumbed in (it has a cold water line and needs drainage). The manual says the steam oven will discharge water at about 160°F.
When water exits the steam oven it’ll run through a provided drain hose that’s about 8 feet long, before it terminates in a standpipe inside a cabinet. For simplicity I’d like to use PVC, but that has a maximum operating temperature of 140°F.
Alternatively I suppose I could use ABS, which I think has a maximum operating temperature of 170°F, although the water is going to mostly drop straight down the stand pipe, hit a trap (where the water will probably be cooler), and then travel maybe another few feet before I’d still have to do a no-hub transition back to PVC.
Is the extra 20°F going to be problematic for PVC? Should I use ABS for that short run so the water cools down more first? Thanks!
