CountryBumkin
Active Member
I was thinking about adding a clean out to my Pool piping. I have in-ground pool with 2"PVC suction and return lines. The PVC line for the pool suction cleaner seems to be clogged, but there is no easy way to clean it out.
I want to add a 2" PCV "Y" fitting (where the angled side would be used for a cleanout) but the pipe made for DWV. Will that be strong enough for typical pool plumbing/pressures?
http://www.homedepot.com/p/2-in-PVC-DWV-H-x-H-x-H-Wye-C4810HD2/100677986
EDIT: I just noticed that DWV piping is rated for max pressure of 5psi, and my pool pump gets up to 20psi on the return side. However this fitting would be on the suction side of the pump, if that matters.
