How much gravel should I put in a 10x54 tank?
Here
Is 15 lbs enough? Finally (finally) getting around to installing this sucker (many thanks to dittohead!).
ditttohead
Water systems designer, R&D
Ontario California
15 pounds is enough. Technically, you should fill the dome with gravel, the dome is .09 Cu. Ft. on a standard 10" diameter tank. This would be approximately 10-15 pounds of gravel.
