How far from a window can a vent stack be? UPC Code
Discussion in 'UPC Plumbing Code Questions' started by Antonio4791, Jul 26, 2010.
  1. Antonio4791
    Antonio4791 New Member
    Jul 26, 2010
    South Pasadena CA
    Hi all,
    I am new here. Hope someone here can answer my question. I am constructing a bathroom within the existing footprint of my home. I am wondering how far from a window a vent stack can be. There is a window nearly directly below where I want to vent. The vent will of course be above the roof, but I need to know how far from the edge of the house it can be. The reason I am concerned is that I have a clay tile roof, which is nearly impossible to walk on. I would like to be install the flashing for the vent by standing on a ladder leaned against the house. But if I get too far away from the roof's edge I cannot do this. Do any codes in California prohibit me from having a vent poke through the roof, say 2-3 feet from the edge of my roof? My city uses California code and doesn't have extra rules.
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Someone from your area will probably chime in soon but in most cases you need to be 3' away.
  4. Antonio4791
    Jul 26, 2010
    South Pasadena CA
    Thanks Doherty, 3 feet shouldn't be a problem. Hopefully there is someone from California out there who can verify.
  5. hj
    There should be no reason why you cannot exit directly above/through the wall, which would place it the distance of the eave from the edge.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    906.1 Vent shal terminate not less than 6" above the roof nor less than 1 foot from any vertical surface.
    I interpret "vertical surface" meaning such surface rising above the roof, not the edge of the roof. Never had the occasion, so I don't know if that interpretation is correct.
    906.2 Vent shall terminate.....at least 3 feet above any operable door or window.
Similar Threads: window vent
UPC Plumbing Code Questions Draining and venting 2nd floor bathroom Aug 12, 2016
UPC Plumbing Code Questions Testing new residential waste/ vent system? Jul 7, 2016
UPC Plumbing Code Questions vertical wet vent kitchen sink Mar 30, 2016
UPC Plumbing Code Questions Running sink drain in same wall as heating vent Mar 21, 2016
UPC Plumbing Code Questions Horizontal wet venting bathroom code question Jan 19, 2016
