How do I remove the handle?
plumb-bob
I have a shower with a single control valve. It is the type that pulls out to turn on the water, then turn left or right for hot and cold. There is a round plate behind it attached to the wall. How do I remove the handle?
Usually, in the center of the knob, there is a cap. Using something thin, you can get under the edge and pop it off. Under there is a screw. Once that is removed, you should be able to get it off.
Verdeboy
Aside from popping off the "button" and locating the screw, the other possibility is a little set screw hidden on the underside of the handle. If that's the case, you'll need the correct hex wrench to remove it.
michealr
Same problem
I have the same problem with the same kind of faucet only mine has a rectangular cover behind it and is an American Standard. It doesn't have a cap and I can't find any set screws. I need help too!! TIA....Mike
michealr
Answer?
Bob, see "Old American Standard push pull faucet" thread for a possible solution to your problem. Good Luck:)
