How do I pull this cast pipe out?
Siber303
Colorado
Siber303
Colorado
what is the easiest way to pull this pipe out? I’ve beat on it it won’t budge..
John Gayewski
Iowa
There is no easy way that I know of. If you just plain pull on it the rubber expands and wants to break the hub.
You could try drilling out the rubber until it's mostly gone, but you might be better off breaking some more concrete and cutting behind the hub.
Is a very strong pull to pull it out. Wriggling it a lot helps.
Siber303
Colorado
Chipped back concrete father it off the main too close to cut
Siber303
Colorado
Heat the portion of pipe you're removing near the gasket to the point it softens/melts the rubber and pull/work it, care not to heat that hub for risk of cracking.
It worked I used 2 torches and I cut a groove in the pipe to use a 2’ pry bar and a block of wood on it. after a few minutes popped right out! Thanks for the tip
