How do i hook up drain to my lift station
carlos007
OK I'm installing an outdoor sink in my backyard and i want the drain to go to the front of the house about 40-50 feet where i have a lift station
I need to know how to do this,
size pipe how many pipes,
does it need to be vented how do i do this,
been reading here seen something about a grinder pump do i need this for the long run
how to tie in to my lift station
for water I'm tie in to the outdoor faucet with a half inch PVC pipe, i think this will be enough pressure its about 35 feet run
thanks in advance for the support
Leejosepho
DIY scratch-pad engineer
www.nonameyet.org
Is this sink for washing hands or for cleaning fish?
Are you planning to run a drain line around the outside of the house?
Do you ever have freezing weather?
I would probably use 2".
Yes, and it might be best to somehow drain and vent this sink by connecting it to the existing plumbing in the house.
If the drain line can be sloped at least 1/4" per foot, no pump should be necessary unless this sink and drain will be handling solids.
The pressure there should be fine, but conecting a pipe to the end of an outdoor spigot is not a good idea since outdoor spigots are not usually designed for being open all the time.
carlos007
washing hands
yes
no
why is that,I'm interested of knowing your opinion but can i use 1 and 1 half
NO can do
No can do,which pump system would i need to use
The pressure there should be fine, but connecting a pipe to the end of an outdoor spigot is not a good idea since outdoor spigots are not usually designed for being open all the time.
Thank you for the advice and help you have given to me so far.
Leejosepho
www.nonameyet.org
Please know I am only a DIY homeowner telling you some of what I would probably do in a situation like yours. I am not a plumber giving professional advice.
As far as I know, 1-1/2” pipe would be fine when connected to a small pump with an 1-1/4” discharge outlet. I just happen to have a personal preference for 2” drain lines.
In your situation, I might place a sump and submersible pump in the ground under the sink ... but I do not know which particular pump or “system” might be best. One challenge here, however, is about how to do that kind of installation without having an “S” trap going down to the sump, and to also get everything vented properly. An outdoor sink drain would work fine without any special venting if it dumps into a 2” horizontal line, but the sump would have to be specifically vented so the pump does not pull air through the sink trap ... and that leaves you with how and where to run and place a vent outside the house and assure no problem with odor coming back out of the sump.
Unless you will be running a large volume of water through this sink, you might check to see whether you would be permitted to simply place a small drywell-type drainage system either under or near the sink ... not much different than dumping a half-gallon gallon of water on the ground after washing one’s hands when the mowing has been completed, eh?!
As I understand it, 2" is the smallest that can be burried. PVC is not supposed to be used for supply lines, CPVC can be, though - similar, but NOT the same. PVC should be fine for the drain lines, unless your local inspector wants something different.
If you can't maintain the 1/4"/foot slope, then you will need a second pump station to get it to the one in the house. Outdoors, you could probably just vent it to the atmosphere there...don't know. You'd want some height so you didn't have to smell it. This may not be reasonably possible, so an island vent scheme could be used and would likely meet local codes. I'd probably avoid an AAV outside, but it might be allowed.
Master Plumber Mark
www.weilhammerplumbing.com
what is this going to be??
I dont know what you are trying to rig up here
sounds like some sort of bar in the back yard by the grill and pool...
Zoeller also makes a little bucket pump that would go under your sink and could pump the water somewhere if
you so chose to do....
If you are hell bent on digging around the home
and running a line to the grinder pump,. a 2 in ch line woudl probably be best, and it would be no problem
just tieing into the vent line comming off the pump...
of course you would need a trap and an AAV vent under the bar...
you could also tie into the water line just about anywehre
carlos007
Bingo
I have an idea of a packaged unit from little giant ( i think),thanks for the help and advice that everyone gave me,i will need more help as i get to the digging thanks again.
