hot water shutting off
Discussion in 'Shower & Bathtub Forum & Blog' started by handijoe, Mar 9, 2009.
  1. handijoe
    handijoe New Member
    Mar 9, 2009
    I have the old 3 handle shower setup. After turning on the hot water, everything is fine for the first 15 seconds. Then a "clunk" sound and hot water shuts off. This happens at the shower head also. Replaced the tub and shower 3 handle set but problem still exists. Help!!!!
  2. jadnashua
    SOmetimes, you end up with a chunk of gunk in the pipes that drops when the flow is off and moves up then blocks things when it is pushed along with the flow.
    You might try removing the hot valve, momentarily turn the water back on while they're out and see if you can dislodge it. If it stops flowing, you may be able to see what it is.
  4. handijoe
    handijoe New Member
    Mar 9, 2009
    Thanks!!! You were right, replaced the hot water shut off valve and problem solved.
Similar Threads: water shutting
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
