My water system is a .75 HP connected to the water mains , pressure tank 24L , pressure switch square D set to 40/65psi . the pump serves 2 separate flats in 2 separate floors 1st and 2nd floors
The problem is that I set the pressure switch to that pressure to let the pump run continous during the shower tap is full open and that is fine and works perfectly , but if somebody else in the other flat used the water tap the water mixture changes and the one gets hot or cold shocks
Any ideas will be very appreciaed
Thank you all
Thank you all
