Honeywell RTH7000 Thermostat
Discussion in 'HVAC Heating & Cooling' started by byrdman, Oct 17, 2009.
  1. byrdman
    byrdman New Member
    Oct 17, 2009
    LaFolette Tn
    I have purchased a new programable thermostat and am having concerns with the drop down period. I mean. the amount of temperature it should drop before kicking back on. I,m thinking 2 or 3 degrees. Currently does not drop at all. Kicks back on before the room temp drops. Help please!
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    you can set that to whatever you want.
  4. jadnashua
    Many of the electronic thermostats do this. You'd have to read the manual carefully to see if it is adjustable. Make sure that you program it to the type of heating system you have (such as furnace, electric, boiler, etc.). They use this information to determine a minimum off time to help keep things from short-cycling.
  5. byrdman
    byrdman New Member
    Oct 17, 2009
    LaFolette Tn
    Thanks Stupid
  6. jimbo
    jimbo Plumber
    San Diego, CA
    Couple of things: Don't know if this is your exact model, but check the heat cycle rate setting, function 0240, page 20. http://customer.honeywell.com/TechLit/pdf/PackedLit/69-1900EF.pdf
    Also, the literature describes this model as having this feature: Precise comfort control keeps temperature within 1°F of the level you set
Similar Threads: Honeywell RTH7000
HVAC Heating & Cooling Honeywell 3210D Wiring Oct 22, 2016
HVAC Heating & Cooling Honeywell 9000 Series Thermostat Installation Help Apr 19, 2016
HVAC Heating & Cooling Lennox to Honeywell Thermostat Jan 9, 2015
HVAC Heating & Cooling Honeywell RTH8500 T-stat Dec 4, 2014
HVAC Heating & Cooling Nest thermostat and honeywell he360a Nov 20, 2014
