Home Inspection Site with Answers to Problems
Gary Slusser
That's all folks!
Well this is one thing I found that is grossly incorrect:
If the water pump apparent "short cycle" is say 1-3 minutes this may be all your system can provide. If however something has changed, and the pump used to run longer, say 2-5 minutes, I suspect loss of air in the pressure tank or an internal problem in the tank (like a hole in the bladder if it's a "captive air" pressure tank). The problem of lost air in the water pressure tank along with how to correct that condition are discussed beginning at SIGNS OF AIR LOSS.
If the "short cycle" is very short, clicking on and off, there could be a different problem with the pump control pressure switch or with a dirty, clogged water filter if one is installed on the system. Dirty water filters as a source of rapid pump on-off cycling are discussed at CAUSES OF SHORT CYCLING.
They also say a PR valve is used to protect the tank... not necessarily so.
And I rooted around in their softener info and they're incorrect in some things there too...
Redwood
I've found them to be a good site for information. They may have some errors but most of what I've seen was spot on!
site
I did not navigate very far through the site, because it appears to be task in itself to find what you need. But from what I did see, it looks like a "fill in the blanks" check list.
Mikept
DIY Senior Member
CT
Home Inspection Site with Problems in Answers .
Gary Slusser
That's all folks!
In our society today we have many people that don't have much common sense or mechanical ability while being paranoid about being taken
So IMO a home inspection site should not have errors especially when the site puts itself out as having expert info done by a pro in the business.
An occasional error is one thing, repeated errors across different fields says that other info may be suspect if not incorrect.
Redwood
In what I have looked at on that site I did not see errors.
I guess you have found some congrats!
Most of what I have seen there was spot on!
I'm not going to adapt a holier than thou attitude but I think I might have seen an error or 2 here... Maybe it was even me:eek:
