Hole in tank too small for 5/16" bolt
Discussion in 'Toilet Forum discussions' started by marcusd, Jan 29, 2008.
  1. marcusd
    marcusd New Member
    Jan 29, 2008
    I'm looking for a smaller diameter brass bolt for the bowl-to-tank connection. One hole accepts the new 5/16" bolt just fine, but the other hole is too small. The old hardware is smaller diameter but its really corroded and I would like to replace it.
    I can't seem to find a bolt with a large enough flat head on it to get a good seal with the rubber washer. I've tried using a stainless washer on top of the rubber washer but water get in between the bolt head and the steel washer. I could use another rubber washer in that joint, or maybe JB weld the steel interface.... Well you see where this is going.
    Any advice where I can get the right size bolt?
  2. jadnashua
    They come in 1/4" too, if that helps.
  4. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    American Standard uses flimsy little bolts if you can find some.
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Use a stainless washer over the leaky new one
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You can probably enlarge the hole slightly with a Dremel tool and a silicon carbide or diamond grinding bit. Use a bit that is too small to fill the hole so you can't wedge it in.
  7. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Any chance the hole has calcium or mineral deposits around it making it smaller? I'd try a small file or something to clean it.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No its a Central Am. Std. Toilet that came with those cheesy 1/4" zinc plated steel bolts....
    Hecho en Guatamala we have outsourced toilet manufacturing to a contry where most of the population doesn't have one!:mad:
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Any decent hardware store will carry 1/4" brass round-head screws and nuts to match, SS washers, etc.
Similar Threads: Hole tank
Toilet Forum discussions Tank to toilet gasket with two holes on side to hold tank May 16, 2009
Toilet Forum discussions Cadet3 elongated toilet, holes from tank to bowl Feb 4, 2009
Toilet Forum discussions American Standard toilet with hole in back of trapway. Aug 6, 2016
Toilet Forum discussions My old toilet has a triangle drain hole. How to plug it? Jun 28, 2016
Toilet Forum discussions found a leak through a hole in the toilet waste pipe Jun 25, 2016
