pennsyscot
Just bought a new home. Well tested high for coloform bacteria. Inspection of the well pit revealed lotsa water, muck, trash and one bull frog. Water seeps through the concrete block of the well pit. The pit is well covered, so entry of debri should not be a problem in the future. Sometimes the water level is higher than the well head. I was planning to run electricity out to the well pit. Thoroughly clean well pit. Install an outlet. Break a hole in the concrete. Install a sump and pump. Remove well head. Shock with household bleach. Replace gasket. Install hose on vent to raise vent higher.
Am I headed in the right direction?
I don't know the depth of the well, can I add too much bleach when shocking?
I would appreciate any advice or suggestions. Thanks, Scot
