Clinger
Hello, I'm new to posting on this forum but have learned a lot reading the excellent post and replies. I need to replace my old Waterboss softener and need some advice. Wife also wants a good quality water source for drinking and cooking.
Old Waterboss, must be a 1-1.5 CuFt system. Has overflowed twice during regenerations, doesn't do a good job softening the water. Needs to go. We have 6 people in the house, 2 under 10. I believe our water usage is in the 300 gpd range. Well water at 35-55 psi using ¾†lines (I can adjust the settings and get 40-60 out of it if needed). Only 1 shower (of 2 in house) is used at any given time. SFR not more than 10gpm, we don't run a lot of faucets at same time.
Had Culligan and Kinetico come out for estimates. Both gave water hardness #s of 24-25 gpg, and Iron level of 3.5 ppm. We get a very noticeable orange stain from the shower/faucets when the softener is not working properly or when the kids forget to add salt when needed. We have a TDS of 480-550. We also have some sediment from the well, but it is filtered out with 2 small filters (old Kenmore unit that needs to go).
Estimate from Kinetico: 735 Unit (dual tank, around 42000 grain I think) along with a K5 RO system and a whole house filter set. Total cost $3800 plus tax. Which isn't that bad (for Kinetico) from what I've read on the net. Culligan unit was a single tank, about 42000 grain, with a pre-filter and RO system for about the same $.
I'm planning on testing the Ph level next week, and also getting a professional water report before making final decisions. I really like the K5 RO system and the dual tank softener from Kinetico, but I think the price is still way too high.
From my research, I think the 42000 grain system is way too small and will need to regen every 3 days or less. This seems to be inefficient. I'd like a system that regens about 5-7 days. I believe I need 300gpd water x (25gpg + 3.5 ppm*5) = 13000 grains per day, so I'd need a 60000-80000 grain system to regen every 5-7 days.
This is what I'm looking at installing myself: A Fleck 9100 SXT Dual Tank 80000 grain softener. A 20†whole house sediment filter, and a quality RO system. Perhaps an iron filter if needed.
Questions:
1. Do I need an independent iron filter system based on the 3.5 ppm iron content? Would a separate media filter such as MediaGuard KDF85 be good, if not, what should I get? Do I go with a smaller softener if iron filter is used?
2. Is the 9100 at 80000 grain (dual tank) overkill? Should I go with a smaller dual tank unit (I want a dual tank option) and why? Calculations for softeners don't account for dual tank options.
3. Should I go with Noryl or Stainless inlet (I'll get the bypass option either way)?
4. Any other help or advice would be appreciated.
Thanks for the time and the information.
Questions:
