Help with mono flow system
Discussion in 'Boiler Forum' started by rodney99, Mar 31, 2009.
  1. rodney99
    rodney99 New Member
    Mar 31, 2009
    I just had my boiler and pump replaced. 1st and 2nd floor seem to be fine giving heat but the basement rads are cold and they used to be really hot.
    this is my system
    http://highperformancehvac.com/boiler-hot-water-loops.html#monoflow_loop
    my heating guy - doesn't seem to be familiar with monoflow systems. I am suspecting that either the pump is in the wrong direction or maybe the velocity is too slow or too fast to get monoflow t valves to operate.
    The supply loop running along the ceiling is hot as hell but the pipes running to the rads below the supply loop are cold as hell.
    Can you help.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Purge the air from the radiators.
  4. hj
    mono-flo
    Posting the MonoFlo site tells us nothing about YOUR system, it just tells HOW it should be installed. Basement radiators could be self venting, depending on how they are connected. For them to operate properly they must use TWO monoflow tees, feed and return, and the flow through them must be in the proper direction, meaning that the return may appear to be backwards if it is not labeled correctly.and they must be adequately spaced to produce a degree of flow resistance between them.
Similar Threads: Help mono
Boiler Forum Need help understanding and adjusting temp on boiler system pics included Tuesday at 7:54 AM
Boiler Forum Need help dialing in a navien ncb 240e Jan 9, 2017
Boiler Forum Need Oil Burner help or advice Jan 1, 2017
Boiler Forum Boiler Issues! Help! Dec 12, 2016
Boiler Forum Please help. Which Boiler to buy? Dec 4, 2016
