Help with Grohe shower valve
Amanfromearth
I would appreciate some help with identifying the grohe shower valve in the attached picture. The closest I could find to it is this: https://www.affordablefaucets.com/g...static-trim-kit-with-lever-handle-p-3500.html
This valve needs to be replaced and it seems that it may be discontinued. Does anyone know if the valve and handle kit can be ordered anywhere. Or, is there some equivalent replacement? I was told the wall needs to be opened up and a new different valve needs to be installed which is not a great option.
The primary issue is that the cartridge needs to be replaced. I am only able to get Luke warm water flowing to the shower.
Neil Binda
Toronto
Hello.
Please see the attached files.
This should help you with the cartridge required.
  • 19230 (1) (1).pdf
