HELP....Starting from Scratch ... found 6" Well in yard
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by NT, Jul 7, 2011.
  1. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    Discovered CI well in yard. It's 125' deep ... water starts @ 75' . Thinking of just using for yard irrigation. What's the easiest/simplest approach. I was thinking deep submersible pump to 3/4" flex line direct to sprinklers. Is this even doable? Recommendations ... PLEASE
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Just because you have 50 feet of water in the well, doesn’t mean it will make enough to run a sprinkler. Of course you won’t know until you try. Use a ½ HP, 10 or 7 GPM pump, set at 120’. A ball valve on the discharge pipe will let you vary the flow out of the system. Try running wide open and see if it holds up. If not shut the ball valve back to 5 GPM and see how long it will run. You have to find out if water will come into the well fast enough to do what you want. The well may only make 1 or 2 GPM for long term. Or it may not make any. You just have to run it to see.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    What's the GPM requirement for the sprinklers? The pump should be matched to the GPM draw so as not to cycle on and off too much. Alternately you could use a CycleStopValve. You won't know how many GPM the well can produce until you drop in a pump and test it.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Ja, low tech could work too. Still, not sure I'd want to drop in a 25 GPM pump only to find out the well can only produce 1 or 2 and have to choke it back.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Welcome to Terry's Forums NT,
    I would put water into the well and make sure it will take water first.
    Before spending a bunch of money, to find that it has been sealed with concrete in the bottom of the casing.
    Enjoy your project.
    DonL
  7. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    Do you agree with using 3/4" pipe is a good approach ... any recommendations where to buy pump?
  8. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    Any thoughts on 120V versus 240 v pump? I'm thinking 2-wire 120v...
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    You're putting the cart in front of the horse. The size of pipe depends on the GPM. IMHO, 240V is always better than 120V and lets you use smaller wire.
  10. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    I think 7-10 GPM should be sufficient.
    If a pump's rating is 10GPM ... I guess it's based on 1 1/4 pipe ... so if I go with 3/4" I'll only get about 3 GPM ... right?
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    LLigetfa is correct as to using a higher voltage.
    But it is best to use the manufactures recommendation on the Pipe size Or output is not guaranteed.
    Go bigger and throttle it back as Valveman suggested.
    That is if your well has any flow of usable water.
    There is usually a reason for a well to be capped.
    Nice that you hit a gold mine. Water is Golden...
    DonL
  12. valveman
    Mar 15, 2006
    Lubbock, Texas
    1/2 HP 10 GPM pump, 230V 2 wire motor, 1" 160# poly pipe, 12/4 wire. Google (1/2 HP 10 GPM sub)
  13. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    Just finished your recommendation. It filled to the top. Does this mean it's probably a dry hole? Can anything be done to rejunivate it ...? redrill it?
    DARN.
  14. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is not going down, That may mean a plugged Hole.
  15. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    Any plan B...
  16. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You Tell us ???
  17. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Find out who drilled the well and why it was capped.
    If you have the money then you could drill a new well.
    The well may have been capped for a reason.
    Drilling a new well may cost a bit of money.
    But that may be a plan B.
    DonL
  18. NT
    NT New Member
    Jul 7, 2011
    Phoenix
    I wish I knew ... that's why I'm asking for YOUR HELP... ANYONE GOT A SUGGESTION ...
  19. gritres
    gritres New Member
    Jun 7, 2011
    nw florida
    bury it and never speak of it again
  20. valveman
    Mar 15, 2006
    Lubbock, Texas
    If a well won't take water, it won't make water. I would say it is a money pit, and you would be better off starting over.
  21. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    If it won't take water, it won't supply water. Since you don't know the history of the well, I'd say it's history.
Similar Threads: HELPStarting Scratch
Pumps and Tanks Well Forum & Blog. Water is life. No water head scratcher Jun 12, 2015
