Help on bathtub overflow cover
Discussion in 'Shower & Bathtub Forum & Blog' started by Kylin, May 3, 2009.
  1. Kylin
    Kylin New Member
    May 3, 2009
    Tennessee
    Hi,
    We are moving in to a new house, and just noticed that the tubs are without overflow cover. I checked *********/Lowe's and can't find anything fit. They all have one or two screws and a gasket, while I can't find any place to screw on. The tube stick out looks like brass tube with a ring on it, which can be taken off.
    BTW, the tubs do have foot stopper for the drain.
    I am attaching a photo. Appreciate any advice can help!
    [​IMG]
  2. hj
    overflow
    Not enough of a picture to tell whose it is, but it looks like it was a "pop up" drain and the overflow may have screwed on or fastened to a screw on adapter.
  4. Kylin
    Kylin New Member
    May 3, 2009
    Tennessee
    On the foot drain it says "WMC 208".
    Should I take the ring off and push the pipe in then add the adapter? It seems impossible to push it fully in.
  5. hj
    drain
    That "ring" is the locknut holding the overflow in place. You could drill and tap the back of the fitting and then use a one-hole overflow plate with a long bolt. You might have to cut some of the thread off it it prevents the overflow plate from contacting the tub.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  7. Kylin
    Kylin New Member
    May 3, 2009
    Tennessee
    Redwood:
    Thank you very much for the WATCO info! I finally have an idea of what to look for.
  8. Mephitis
    Mephitis New Member
    Oct 24, 2011
    Virginia, US
    Bump. I have a similar problem, I inherited the rough plumbing and need the trim. WATCO says they did not make it, and indeed the catalog looks somewhat different. Photo attached. Anyone have any ideas? Note this is the overflow up on the vertical wall of the tub, not the drain in the floor. TIA
  9. ergirl64
    ergirl64 New Member
    Mar 26, 2012
    Virginia
    I Found the parts
    Hello, I also have the same conection on my bathtub and needed the same part. I found where to get it. It is from Watco. I ordered the parts @ http://www.buyeagle.biz
    The part number and name: Item No: 01004CP
    Description: Watco - Innovator® Plastic Overflow Plate
    Hope this helps
    [​IMG]
Similar Threads: Help bathtub
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Stone bathtub drain help needed Jul 7, 2016
Shower & Bathtub Forum & Blog Need help picking a bathtub waste overflow (BWO)/drain Jun 17, 2016
Shower & Bathtub Forum & Blog In need of bathtub help! Nov 29, 2015
Shower & Bathtub Forum & Blog Leaking bathtub faucet. Need help identifying three handle variety. Dec 18, 2014
