Help. Moving Well Pressure Tank and Switch.
Koches
Parkton, MD
Greetings,
Due to a bad bladder, I am installing a new pressure tank (Amtrol WX-202) and taking the opportunity to relocate it from the well pit outside to inside the basement.
Knowing that the pressure switch should be as close to the tank as possible and most commonly placed on a top port of the tee assembly, I do not understand how to properly move the new switch inside because the current switch is attached to the well pump (Goulds J5S) and is fed from just 1 wire which is connected into a box (junction?) containing a wire that runs to the electric panel inside the house.
Please see picture and let me know your thoughts.
Thanks in advance.
Brian
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A wX202 only holds 5 gallons of water. The old tank went bad from cycling on/off for every 5 gallons used, which broke the diaphragm. You should add a Cycle Stop Valve to solve the cycling problem while you are at it. You can just add another pressure switch to the tank cross and wire around the existing switch on the motor. You can see how to wire around the existing switch from the wiring diagram for "jet pumps" in our PK1A instructions.
Koches
Parkton, MD
Update:
After adding new switch (40/60) at tank cross and wiring around the old switch (30/50) on jet pump, I noticed the pump continuously runs even without a call for water. Any idea what could be going on?
Thank you in advance.
Update:
When the pump runs, what does the pressure gauge indicate?
When the pump is off and you are not using water, what does the pressure gauge indicate?
When the pump is off, what does the pressure gauge indicate if you open a faucet?
What do you mean by "call for water"?
