Hard to remove fill valve
Discussion in 'Toilet Forum discussions' started by ahaddad, Mar 21, 2007.
  1. ahaddad
    ahaddad New Member
    Mar 21, 2007
    Michigan
    Hi all,
    I'm a new homeowner and I need to replace my first fill valve. I can't get the old one off! The nut at the bottom of the tank is completely stuck. I tried for two hours last night with no luck (well, I got the lower one off but the one that's in contact with the tank won't budge). Any ideas or tricks about removing it?
    Thanks,
    Alex
  2. hj
    valve
    Unless it is a brass fill valve with a "pot metal" nut, it should not be that tight so you may be doing something wrong. If it is really that tight, you might want to call a plumber before you crack the tank and have to buy a new complete toilet.
  4. ahaddad
    ahaddad New Member
    Mar 21, 2007
    Michigan
    Good point. Maybe I'm using the wrong tool. The thing is plastic and I was trying to get it off with a wrench. The whole assembly turns when I try to loosen it.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    You will have to hold the inside piece with your hand while applying the pliers to the underside nut. All else fails, very carefully hold a hacksaw blade inyour hand and cut the nut. On an all plastic set up, this should not be necassary. It will come loose.
  6. maddog
    maddog Engineer
    Aug 1, 2006
    Software Engineer
    near San Jose, CA.
    I had the exact same problem removing a plastic fill valve. It would just spin around in the tank while turning the plastic nut on the bottom. I used a hack saw blade, which easily cut through the threaded part of the valve. I then carefully cut about half way through the plastic nut and was then able to pry/separate/split the nut with a thin blade screw driver. -dog
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Cut it off.......
  8. hj
    nut
    If it is plastic, heat a screwdriver with a torch and melt a groove up the side of it, then snap it off the thread. You won't have to worry about damaging the tank or anything else doing it this way.
  9. ahaddad
    ahaddad New Member
    Mar 21, 2007
    Michigan
    It's FIXED
    Thanks for all the suggestions. I couldn't get anything to work.
    Then my dad came over and chiseled it off in 10 seconds!!
    I HIGHLY recommend that method!:D :D :D :D
  10. sheltie1
    sheltie1 New Member
    Jul 26, 2016
    California
    In case anyone with metal plumbing reads this, I will let you know the answer that worked for me. I scrubbed the nut under the toilet with a wire brush and WD-40. Then I clipped a vice grips to the fill valve base inside the toilet. Once those two steps were done, I was able to unscrew the screw under the toilet for the fill valve attachment without any further trouble.
Similar Threads: Hard remove
Toilet Forum discussions Drake or Drake II (has anyone successfully removed hard water stains from Sanagloss?) Mar 10, 2014
Toilet Forum discussions Soft close seat: Ugly sticker hard to remove, upgrade to a Washlet Nov 20, 2008
Toilet Forum discussions Can't decide which toilet to buy...large/hard BMs Mar 2, 2017
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions What toilet? How can it be this hard?? Nov 22, 2016
